Threaded View
    Hi CNC Experts
    For some time now I have planned to build a 3-axis CNC router. I will primarily use it for wood working, mainly loudspeaker building, but also for general wood working including dovetail joints. However, I would also like to use it for work in aluminium, mainly for making front and rear panels for electronic cabinets and for engraving them. I could also imagine using it as a 3D printer.
    I have looked at various home pages and forums for inspiration, but MYCNCUK seems to be most in line with my own ideas. So after having learned from the projects on these pages, especially the machines described by EddyCurrent and Kingcreaky, also comments from Jazz have been very useful, I have made some drawings and a part list, and now I would really appreciate any comments on this, before I start buying parts and putting them together.
    Work area: X-axis: 733mm, Y-axis: 580mm, Z-axis: 220mm
    Frame made of 50 x 50mm and 50 x 100 (3mm) steel profiles. I intend to use the epoxy self-levelling support technique (30 – 40mm wide channels, 5mm thick).
    Gantry made of aluminium profile.
    Mechanical parts:
    • Ballscrews (C7): RM1610: X-axis: 1015mm x 2, Y-axis: 800mm x 1, RM1605: Z-axis: 340mm x 1
    • Ballscrew supports: BK12 (fixed end) x 4, BF12 (loose end) x 4
    • Ballnut housing: 1610 x 3, 1605 x 1
    • Linear rails: Hiwin profile 20mm, HGH-CA (HA, CW)), standard preload Z0. X-axis: 1000mm x 2, Y-axis: 750mm x 2, Z-axis: 416mm x 2
    • Pulleys: 20T, 21,8mm Dia., 8mm hole x 8
    • Belts: 15mm HTD, 1:1, (20T : 20T).
    Electrical parts:
    • Stepper motors: Nema 23 - SY60STH86-300BBF, x 4 (parallel connection)
    • Stepper drivers; Leadshine EM806, EM860 or AM882 x 4
    • PSU Linear, 70V, 9A. 500W toroidal transformer (rectifier, capacitors, softstart)
    • Controller Smoothstepper, or Pokeys57E
    • BOB Machschmidt BOB v1.5, OPPBV3 (DIY CNC) both require separate spindle control board (e.g. SP5 V5 Spindle Board from DIY CNC). Alternatively Chinese board with built in spindle control: http://www.ebay.com/itm/6-Axis-CNC-M...item1c3dfdfbde
    • Spindle motor: 2.2KW with VFD and water cooling.
    Software;
    • Control SW: Mach3 or 4.
Name:	Complete w spindle up top.jpg
ID:	16079   Click image for larger version.
Name:	Complete w spindle up back.jpg
ID:	16075   Click image for larger version.
Name:	Complete w spindle up right side.jpg
ID:	16078   Click image for larger version.
Name:	Complete w spindle up left side.jpg
ID:	16077   Click image for larger version.
Name:	Complete w spindle up front.jpg
ID:	16076   Click image for larger version.
Name:	Complete w spindle up.jpg
ID:	16074   Click image for larger version.
Name:	Complete w spindle down.jpg
    Last edited by ngundtoft; 17-09-2015 at 07:50 PM. Reason: Thread disappeared from forum and drawings were lost
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. My new, and first build....comments greatfully received
  4. Help appreciated
    By joncdrl in forum Milling Machines, Builds & Conversions
    Last Post: 17-09-2012, 08:34 PM
